Hi guys, I've had a new keel housing bracket made up but wondering why there are 4x holes?
surely only two or required? one for the pivot pin and other is for the sheeve.
Why have different locations?
Question is which are the correct ones to use? I have found drawings and photos which show different ways.
I have attached a photo of the new bracket and the wear suggests this was how it was fitted but the sheeve in the lower position bottoms out on the keel before it goes 90degrees also the original sheeve is too wide to locate in the upper hole, it only fits in hole #2 (counting from top).
So I'm a bit confused, maybe it didn't function correctly before?
Any advice appreciated.
thanks in advance!
thanks in advance!
