H240 keel housing bracket pin locations
May 1, 2021
15
Hunter 240 Southampton
Hi guys, I've had a new keel housing bracket made up but wondering why there are 4x holes?
surely only two or required? one for the pivot pin and other is for the sheeve.
Why have different locations?
Question is which are the correct ones to use? I have found drawings and photos which show different ways.
I have attached a photo of the new bracket and the wear suggests this was how it was fitted but the sheeve in the lower position bottoms out on the keel before it goes 90degrees also the original sheeve is too wide to locate in the upper hole, it only fits in hole #2 (counting from top).
So I'm a bit confused, maybe it didn't function correctly before?
Any advice appreciated.
thanks in advance!
-na -NA Anywhere USA
Anyone with a water ballast 19 , can you advise please.
If no one responds, I will try to find out for you. The bracket was used in five different sailboats.
May 1, 2021
15
Thanks Crazy Dave, that would make sense it was used in multiple boats. Surprised there isn't more holes if it was used in 5 different ones
May 1, 2021
15
Caverun has this posted in the 240 downloads section.
As mentioned by Crazy Dave the same bracket is used in multiple hunters - I believe the 240 and 260s use different pin locations.
great thanks for sharing that, although I can't get the full range of movement of I use that pivot pin location hole.
Makes sense it was made for 240 and 260.
just need to find the correct way around or why it doesn't work one way on mine but seems to on others. I feel like I'm missing something
