Possible to find a replacement...
In just about any marine store. West Marine, Boater's World, or Boat/US ought to have a replacement that will fit. It should be noted here that the emphasis is on "will fit"- It may not be an EXACT replacement, but it will give you the ability to steer your boat! On our H25, it appears someone replaced the original tiller, but used one that has WAAAAY too much curve in it. We just put a new tiller on today, and are happy with the results. One final note, Be careful when you drill the holes in your new tiller- Make sure you're drilling straight through the wood! I was off by a little for one of the holes, and had to re-drill. You can't tell from the outside, but one of the bolts may not be working as hard as the rest... ;o)--Jon BastienH25 'Adagio'
