I have never had to replace the car, and unfortunately don't have photos of mine. However, if you have to remove the track to do this replacement, I would seriously consider (while it is removed) adding cam cleat/block assemblies at either end of the track and get rid of the two stops. Look at the improvement in Peter Suah's mods. Go to Boat Info, Hunter Owner mods and pick the 23. Scroll down to his post "Hunter 23 traveler mod". I did that to mine and it is much better, I can actually adjust the traveler position and it isn't rattling back and forth against the stops.
