H23 Jib & Spinnaker Halyard Blocks in Mast
Hunter 23 Tampa Bay
About an hour after I posted I figured it out. I did go back to rigrite and have found the correct sheave for the jib halyard. Took a while to go through their lists but all is well.
Thanks!
-na -NA Anywhere USA
carboman;
if your mast is z spar, go to US spars site and order as they are the z spar masts and fittings but under a different name. will not go into what happenned but there you go.
crazy dave condon
