I have some fiberglass cracking around the bow eye (U bolt), and the holes have always been a bit large. I took the eye out this season to fix, figuring I'd squeeze West epoxy thickened with structural filler into the holes then redrill.
In cleaning them out (from the outside) with a small screwdriver, bits of soft wood that I assume is balsa core came out - a fair amount. I cleaned the area out as best as I could then injected the epoxy mix, and can see from the inside it filled up to the metal strap backing plate for the eye.
How is this area designed, and where would the balsa core have come from? The metal backing plate does not look stock to me. It is about an inch wide, and extends up from just below the lower stud of the eye up toward the deck - I am wondering if this is also a chain plate for the forestay?
