Question
one....Motor mount board has cracked lengthwise in the middle.Should I replace it with an orginal board( possible teak) from marine parts supply....or with 2x6x17.5 weather treated (green)standard board from lumber yard?.
Its depth would be a little differant 1 5/8 rather than 2 inch?
The four anchor bolts have no nuts on back that can be seen from looking under cockpit area.
Question
two....I want to check trailer wheel bearing and repack my wheel bearing with some warm weather day this winter.I bougth two "Grease buddies", that have threads. To replace the standard caps on wheel now.Can anyone give me advise on type lube and tips.
I have a lot of grease thrown /leaked out all over the outside of my one wheel.Cap was not put on tight when last checked I subspect..?
Txs in advance guys...awesome group.:dance:
Question
