H23.5 Front Hatch Replacement
337
Hunter 27-3 Brownsville, VT/Mystic, CT
With the greatest regret, I confess we didn't get Grasshopper's keel wet last season due to baseball schedules, crummy weather & other summer activities. We have rectified that gross omission this season, though it has been a late start. As they say, better late than never.
At any rate, when I pulled off the tarp & began to reacquaint myself with the old girl prior to launching her last month, I discovered to my dismay that the front hatch had a crack along the bottom edge and a piece of gelcoat had come away. Rain water, melted snow, etc had seeped in over the prior 20+ months, and the core of the hatch is going in several areas, especially where the gelcoat is gone.
Has anyone replaced their front hatch? I emailed Hunter, and the reply suggested they probably have an OEM replacement. However, I'm considering replacing it with a smoked glass affair if possible. In my ideal scenario, I find a hatch with the correct dimensions and swap out hardware. I'm definitely not eager to cut a new opening and install a new frame, etc.
I'm probably dreaming here, but I thought I'd try here to see if anyone has gone this way before. Thanks, in advance, for any insight on this issue.
Dec 2, 1999
15,184
If your frame is still good, you can contact Select Plastics and they can replace the lens for you.
