H 41 roller furling mást spy hilyard replacement
Feb 10, 2017
305
Hunter 41 Progreso
I lost my hilyard and i need to run a new one inside the selden mast, if i try to run a line tru the mast from the top opening were the hilyard will came off , after 6 feet it wil stop from coming
Any tips on how to run a líne inside this mast¿
7,725
Alden 50 Sarasota, Florida
Assuming you don’t want to run the halyard through the dedicated chase, an old style window weight might be thin enough to avoid any obstacles
Jan 7, 2011
5,999
Oday 322 East Chicago, IN
I saw someone tie a stack if small nuts on the end of the messenger line, and drop it down the inside of the mast...pretty flexible stack of weight, so easy to fish out at the bottom.
Greg
Jun 11, 2011
1,243
Hunter 41 Lewes
Talk to Selden, I think there is some styrofoam inside the mast to keep the halyards from slapping inside. I'm sure there is a trick to it and they would know what it is.
