H 37 Cutter Water Tanks
48
Hunter 37 Cutter St. Joseph, Michigan
The tanks on my recently purchased H37 Cutter are leaking. They are the original tanks. What is my best ("best" defined as long term, healthy solution) alternative for correcting the problem? Repair or replacement? If replacement, can you point me to the source for the new tanks? Thank you.
Jim
Jun 21, 2007
2,118
Why don't you try also on the Cherubini Hunter forum. By "cutter", presume that you have a Cherubini Hunter.
Hunter 37 C sloop Punta Gorda FL
Try a "search" There must have been others with leaky tanks.
Personally, I doubt that you will find a new replacement. We have had great luck with Ronco plastics for holding tanks. they have Hundreds of models. Here in Sw Florida you can get custom stainless tanks, but they are expensive.
Johnb
Hunter 37-cutter Richmond CA
Click on "Boat Info" at the top of the web page, then click on "Hunter Owner Modifications", then click on "37 Cutter" then find "water tank fix" by Richard Shelby" and "replacing water tanks" by Renasci.
There is an incredible wealth of information in this web site.
