My 1994 H-26 currently has the standard setup with the reefing line through the Z- Spar boom and out the jam cleat on the forward end of the boom. With this setup the reefing line only pulls the aft reefing cringle down to the boom. I still have to go forward on the deck and manually hook the forward reefing cringle onto the ramshead hook. I would like to use a single line reefing system that pulls both fore and aft reefing cringles down to the boom. One drawback is currently, I have a sail slug about 3 inches below the forward reefing cringle and have to manually remove the sail stop, slide the bottom sail slug down below the sail track opening, then re-insert the sail stop above the bottom slug. Has anyone developed a single line reefing system on the H-26 or similar "sister" models. A description and possible a photo your sytem would be very helpful. Thanks, BrianW
