H-26 Rigging
N
Neil King
Can anyone advise me on proper rigging of a '94 Hunter 26 water ballast? When I look at the boat from the port side, should the upper and lower stays cross at the chain plates mounted on the hull? The chain plate U-bolts are mounted side-by-side on the hull. Does the lower mast shroud toggle attach on the front or rear chain plate U-bolt? Thanks for the assistance.
N
NORM STEFFEN
Lower shroud should go to Aft chainplate U-bolt. I would suggest ordering a owners manual from Hunter. It's well worth the about $20 price; answers lots of questions. Good luck. Norm Steffen
Ray Bowles
Neil, Norm is right on about the owners..
manual. Not only must the shrouds be correctly mounted, they must also be installed on different sides of the lifelines etc. Then they must be tensioned correctly or, at worst, you could suffer a catastophic failure and lose the mast. You must also pay special attention to the shroud toggle bolts when raising the mast or you will bend them and thereby ruin them. There is alot of information in the archives on this site about this subject on H26's. Do it right and she'll sail straight, hard and fast safely, and safe is the KEY word. Good luck, and after you get a manual and read it, there are a bunch of people on this site that can then slowly walk you thru the whole bit on mast tuning. I know, as they did this for me last winter and now I dream about these numbers and the difference they can make. At my age, and with the body I share with the little gremlins it attracts, dreaming about sailing is great. Ring back when your ready to tune. Ray s/v Speedy
