Alright, I'll go against the self proclaimed God of all things Hunter. Is it just me but, Wow, "If you don't know who I am others will tell you"???? Really, you tell us in every post.
A CB bolt failure nearly happened to me. See a pic below of my 5y/o CB bolt that I checked, only to find it was already 30% destroyed so at least you're on it.
Cutting out a stripped bolt is nearly impossible without destroying the housing so decide early how far you want to go. I suppose a line of 1/4" holes slowly drilled all the way around the bolt head would be a last resort, but omg that'd be a terrible job. A newly fabricated SS base plate or huge fender washer and 1/2 a tube of 5200 or butyl tape would get it sewn up after surgery.
Granted it's easier to hire a lift but if you're a capable tool guy with a friend, obvious caution and a hydraulic jack and don't have the cash I'd remove all the major weight from the boat that I could, and lift it right on the trailer. I'd lift the trailer on a flat driveway/slab a bit and block the frame well. Lift the boat in slow progressions and finally block it at the sling zones front and rear and the bow section with some stout carpeted 2x12 cubes and get after it. It only has to come up 12-14" off the CB rest for the CB to come out. Pull off the trailers' CB rest if you need some more room.
The bolt's stripped for sure, or worse, the nut on the housing has corroded loose. That being said maybe some grunt at the factory was told to glue the CB bracket to the upper housing which will make it much tougher/impossible to get loose. Otherwise it'd come out of the slot with a minor bit of convincing, like lowering the CB enough to place a wooden block between the boat and the CB near the head somewhere while gently lifting upward on the tail.
Again, going against the Grand Potentate, aligning the bracket is actually VERY simple thanks to the ingenuity of another user who wasn't satisfied with only one way of doing things and shares his ideas openly on the forum. Just strap the funky banquet table to the cabin ceiling, cut a 14" piece of 3/4" all-thread and screw it into the bracket, lift the board and bracket near the slot and push the all-thread into the main bolt hole. Now you can either run a nut and a sleeve on the rod to draw it up (perfectly aligned every time), have your volunteer lift it with the rod or just lift the head into place from below if you've eaten your Wheaties. After removing the rod from above, put your new SS 3/4" bolt in place with a fairly snug fit, lather the whole thing with 5200 and you're golden after it dries for a few days.
Hope that helps and please post your success along with what you learned in the process.
All my best to you in your efforts, Mike
