H 240 table
Jul 25, 2021
3
Hunter 240 Titusville
looking for a table for my 240, has a V lock mount on port side. Even a source for new one would be great.
Chuck
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Welcome to the forum!!
What is your table configuration? Does it fold down from the port side or stern like this one? I would be inclined to fabricate one in teak or marine grade plywood covered with formica to your liking that folds down.
  • Helpful
Likes: JamesG161
Jul 25, 2021
3
Yes I have the fold down table. What I am looking for is a more centrally located table so both seats can be used.
Feb 18, 2011
315
Hunter 260 Cave Run Lake, KY
Here's the stock 240 table in my previous boat- it mounts on a vertical slide-in bracket in the cabin and in the cockpit. The post does not fold or detach, so a bit awkward to store when not in use.
3
That is what I am looking for! It does sound a bit awkward but I have got to try it if I can find one.
-na -NA Anywhere USA
Look under the V berth to see if one with leg is stored. The 23.5 and 26 were standard for the pictured table provided by @caverun
However, Hunter did away with it on the 240 & 260. I believe the table on the 240 pictured here was an add on. The storage area remained on the 240 and 260 as the molds remained the same. I may be wrong on the 240 but you could check with the forum store if it is available. They do have the build list for your boat do you can check with them
Jun 28, 2020
12
Hunter 240 Saefern Dock
On the 240 the table is a pain in the a$$. It is hugely in the way while sailing. Even in port / moored it's really difficult to navigate around it.
Likes: patbratton
Sep 13, 2021
157
Catalina Capri 26 280 Lake Jacomo
We really like having that table. It's great when you're just hanging out with friends or family and need a place to set snacks or drinks. For casual maneuvering it's sized so that the tiller clears it. It's also super easy to plug in below in the cabin to get it out of the way or to use in the evening when staying on the boat.
