GX2150
Feb 2, 2013
33
Beneteau 351 Bluewater Bay
Anyone integrated Standard Horizon GX2150 VHF with Raymarine E7 chartplotter?
May 20, 2016
3,015
Yes mine is. It gets gps info from the e7D and AIS is sent to it - so two separate 0183 networks. What do you want to know??
Nov 16, 2012
1,055
I interfaced a GX2200 to an e7D. They trade GPS info and the GX sends AIS to the e7D. I used unsheilded twisted pair Ethernet cable for the wiring run (Nav station to steering pod).
@whittem Reach out to Les. He really knows his stuff on this subject.
Feb 2, 2013
33
My GX2150 and e7 manuals show the following:
e7 MFD Port 1:
white: Input +, green: Input -, yellow: Output +, Brown: Output -
GX2150 (No GPS in radio):
green: NEMA Common ground/-, blue: GPS input +, grey: DSC output +, brown: AIS output +
GX2150 manual says if using one MFD NMEA port, then set up MFD at 38400 baud I/O to send GPS to GX2150 using blue wire and receive AIS/DSC from GX2150 using grey wire. GX2150 Brown not used. So looks like 2150 sends both DSC + AIS over grey wire.
So e7 to GX2150 wiring diagram will be:
e7 GX2150
white (I+) grey (O+)
green (I-) green (O-)
yellow (O+) blue (I+)
brown (O-) green (I-)
Leslie/Rob- Look OK?
Nov 16, 2012
1,055
Odd that the 2150 uses the same wire for - on both input and output, but if that's what the manual says, I'd try that. Makes sense that DSC and AIS would be sent on the same wire/port.
Nov 16, 2012
1,055
Common ground is fairly common on 0183.
Agreed, but the GX2200 has separate grounds for input and output. They actually say to leave the NEMA output (-) open if the chart plotter has only one wire for signal ground.
