Guys described RO system is OK. However, the recent price escalations of Stainless Steel (needed for the high pressure connectors and the high pressure regulator) has gone 'sky-high' due asian demand and the drastic decline of the $US. These pricing penalties coupled with an essentially idle 'watermaker industry' should prompt one to 'see what's available - already built' ... as you may find real bargains as these builders/distributors unload their stock.
A Water maker is easy to build, even an engine driven RO. You can easily build a 'manual' controlled RO, which is the cheapest.
For a long lasting RO machine use stainless steel hose connectors and *bronze* head high pressure pump.
There are some inexpensive DIY watermaker build/construction/parts lists available on the internet - do websearch: lichtfeld + watermaker
I note that your location is Georgia .... not a good place to operate a watermaker due to the high turbidity (solids loading) in the local water; you'll be forever changing out the needed prefilters. A watermaker is principally only used in CLEAN/CLEAR seawater.
