Gulf Loop Current forecast
2,422
Whitby 55 Kemah, Tx
ok...here it is
(https://www.navo.navy.mil/cgi-bin/animate.pl/metoc/40/84/0-0-17/2)
Jun 12, 2004
1,181
Allied Mistress 39 Ketch Kemah,Tx.
FRANKLIN .....HELP !!!!
I went to the website from your link and could not access it Then i cut and paste the adress and here is what i got (See Below). Should i 'Continue to this website'? : There is a problem with this website's security certificate. The security certificate presented by this website was not issued by a trusted certificate authority. Security certificate problems may indicate an attempt to fool you or intercept any data you send to the server. We recommend that you close this webpage and do not continue to this website. Click here to close this webpage. Continue to this website (not recommended). More information If you arrived at this page by clicking a link, check the website address in the address bar to be sure that it is the address you were expecting. When going to a website with an address such as https://example.com, try adding the 'www' to the address, https://www.example.com. If you choose to ignore this error and continue, do not enter private information into the website. For more information, see "Certificate Errors" in Internet Explorer Help.
Jul 20, 2005
2,422
Whitby 55 Kemah, Tx
yes
That is a message the browswer gives you if the certificet isn't registered. It is a government website and is safe. You will be prompted several times (one for each control on the page...about 5 or 6).
Oct 23, 2005
43
Hunter 25_73-83 Lakewood, Ohio
Thanks for that link Franklin!
And best of luck to ya on your trip!! Fair winds and smooth seas both ways! CharlieH
Jun 12, 2004
1,181
Thanks
I knew u would turn up something, Thanks. If im reading this right, its only about 2.7 mph now at its worst spots.Thats still significant on a long trip. When we got caught up in it it was running at least 5 knots as a guess. The vid clips i sent you from offhsore looked like it was about 4 or 5 knots just by looking at the bubbles. If for some reason you go to say, Appalachacola and head south, u wont hit it. when we were coming back from Tampa bay area , we hit it hard. wind was also dead on our nose for a few days. We tried tacking and were moving about 6.5 to 7 kts steering 45 degrees off our intended course, and were actually losing ground. We motored for what i think was 2 or 3 days with the sails up, on our rhumb line and were only making about 1.25 to 1.5 kts to the good. Have plenty of diesel. if you can get to work with the current, it will be a fast ride. This still doesnt make me any less jealous. Tony B P.S., i wonder if they transmit this data over SSB like they do with the regular forecast charts. Then I'll talk u into a HAM liscense, which they are just about giving away now, and you can get on shiptrak.org so we can follow you.
Jul 20, 2005
2,422
Whitby 55 Kemah, Tx
Chart
notice that the scale is in meters per second, not knots. I don't know if you did the math to come up with the 2.7 or mis-read it. I was too lazy to do the math :)
Jul 20, 2005
2,422
Whitby 55 Kemah, Tx
hmmmm
I came up with 2.7 also. There has to be something wrong there. No way is the Gulf stream only 2.7 knots. Anybody got a clue?
Jul 20, 2005
2,422
Whitby 55 Kemah, Tx
better chart
(https://www.navo.navy.mil/cgi-bin/animate.pl/metoc/40/84/0-0-17/0)
Jun 12, 2004
1,181
Something is missing
We are missing something here. We need an explanation of the chart. I see negative numbers, that, one could reason, would be a reverse flow, but why negative numbers when they have arrows? At times the Gulf LOOP can slow down, it is everchanging. The loop is created by warmer water flowing into the gulf, and at this time of year, the loop would be much smaller and also possibly bucking the tidal flow into the Gulf. Hell, im just guessing, but it sounds good, LOL. When i took those video clips out at that platform, i think i was about 60 to 65 miles south of the mouth of the Ms. river. Ill have to check my old time sheets to figure where i was. Anyway, the current was hauling ass for the full 2 weeks i was there, except for 1 day it slowed down to a crawl , then picked up speed again. Some of the ststic charts i found on the internet show it as coming way west and way north as a continuous clockwise loop with an Eddy off the west coast of Florida in an irregular shape. The guys on the platform said its usually always screaming on through, though. Wish i had the time to research it for you. You are a puter guy, just hack into the system and ask to speak to Bubba the Forecast guy.
