Guest Galvanic Isolators
RitSim
Jan 29, 2018
412
Beneteau 411 Branford
Adding two galvanic isolators to my AC system. The diagram shows the Guest Isolator in series with the AC ground and also connected to 12 Volt DC. Do I have to be concerned about battery loss if the Isolator is always connected to the DC? Does the DC connection always need to be energized to the Isolator?
Feb 6, 1998
11,672
Model # of the GI would help.. Some are no-longer safety complaint...
Feb 6, 1998
11,672
That galvanic isolator should not be used. They "test" the ground wire and this will cause nuisance tripping on ground fault equippend docks (NEC / NFPA code) where you could take out every boat on the pier. The current ABYC standards call for a "Fail Safe" galvanic isolator.s. SBO is currently out of stock but we have a few.. 30A Fail Safe Galvanic Isolator
RitSim
Jan 29, 2018
412
I have two (30 Amp) shore power connections that are bonded together at the AC panel. Can I use one fail safe 70 amp galvanic isolator?
Consider the ProSafe FS60 Isolator
  • Use the ProSafe FS60 for (1) 50 Amp or (2) 30 Amp Shore Cord Applications
