The last time I used shore power to charge my battery there was a humming sound coming from the charger. The boat is usually on a mooring so I do not use the charger that often. I checked the charger today as one of my winter projects. Apparently the PO rigged an inline fuse (blown fuse) on the DC ground wire going to the ground bus bar on the DC panel (I don’t think anyone can top this). The charger is an older Guest 30 Amp (model # 2530A) 3 output model. I tried unsuccessfully to find a manual for that type charger. Is anyone familiar with this model?
