I have '76 Catalina and am getting a little water in the bilge. It is probably rain water that has saturated the flotation. I sponge it up and, next day, there is some more which means the foam is probably holding water and releasing it. But, I have also read that the gudgeon mounting bolts can leak over time. Since mine are original, I am thinking of replacing them.
Here is what may be a dumb question. I have seen the gudgeon fastener kit on Catalina Direct's site. And also looked at the gudgeon access kit which they say you can use to "access the top gudgeon mounting bolts from inside the cockpit. " Which is all well and good, but, how do you access the mounting bolts for the lower gudgeon?
Is the lower gudgeon mounted directly into solid fiberglass? If not, how do you get at the bolts?
