Ugg, it's too hot to sail, or to work on them either. So, I'll kind of respond.
If you're looking for advice on how to hook up your juke box, I think that's pretty much been covered. So in an overt attempt to hijack this thread entirely, I apologize in advance..
To get a rebuttal from Maine Sail is actually a compliment. I consider his advice to be the final authority online, on anything marine related, I really do. Still do.
I think part of my posting something I'm not sure about, or even a totally crazy idea, sometimes net me the most results. I used to write a column on religion or politics that the editor purposely wanted me to raise the ilk of respondents, and having no opinions either way, on either subject, I was the ideal candidate. This habit persist evidently...
On the bonding issue, the thought that I have seriously considered, is to bond all the thru hulls together, and run a dedicated anode to them only. That would leave my galvanic isolator to deal with the prop and shaft. I don't know any corrosion specialists, but after extensive "research", and two very respected marine companies that frequent the yard got to weigh in on it.....nobody knows. When I posted this question on another site, that is dedicated to this boat in particular, the response was meager. I even posed this to our local Witch Doctor in residence, and he mumbled something about boiling a cast bronze thru hull in his cauldron for awhile, and went wandering off kind of googly eyed toward the beach.
So, I wish that there was some known parameter. It is all too vague. I like firm calculations, solid math, or at least an equation to work from. If an alternator fails, the repair is simple. It either works, or it doesn't. On or off. Yes or no. But here, the variables are infinitesimal.
And there are more opinions on this than politics or religion.
A lot of this is just supposed to be funny. If anyone can set me straight, I truly welcome it.
Nor to imply any disrespect to our friend Maine Sail. His advice converted me to Sika 291, without which, I would end it all...
