Reply to grounding thru-hulls
Scott,We are often confused by what we read or are told and what we see on our boats. The following is a quote from the USPS Marine Electronics course regarding bonding systems. I apologize in advance for the length of the reply; however, it answers your question about bonding thru-hulls."Even a sailboat without electricity should have a bonding system for lightning protection. This consists of a wire running from the air terminal, down the mast, to a large underwater metallic surface. This should be a minimum of #4 AWG copper or equivalent cross-sectional area. Attached to this vertical conductor is the bonding system which should be a minimum of #8 AWG. All metal objects that could normally contact a human should be connected to this bonding system. The bonding conductor consists of a normally NON-CURRENT-CARRYING CONDUCTOR (my bold-face), running fore and aft, and used to connect the NON-CURRENT-CARRYING (my bold-face) parts of the DC devices and metallic parts of the boat construction to a local ground of the wetted hull, the same point as the negative terminal of the battery. The purpose of bonding is to keep all metallic parts from getting either a static charge or a magnetically induced potential due to a lightning strike.The bonding conductor need not be insulated. Preferably, for ease of attachment a 1/16inch x 1/2inch copper strap, or a length of soft 1/2inch copper tubing makes a more workable and durable installation. This conductor should be supported well above the bilge-flooding level.... The bonding conductor is normally grounded through the engine casting and drive-shaft assemblies or to a submerged, wetted-surface, copper ground plate.Bonding conductors should be extended to contact: a. Metallic enclosures of all DC electrical equipment. b. Motor, generator, and pump frames. c. Fuel tank, deck fuel fittings, fresh-water tank. d. Metallic mast, stanchions, railings, standing rigging.DO NOT BOND METALLIC THRU-HULL FITTINGS SUCH AS SEA COCKS OR HEAD VALVES.(my bold-face) These should be isolated from the bonding system for two reasons: TO ELIMINATE A PATH FOR LIGHTNING TO BLOW OUT AN UNDERWATER FITTING, AND TO PREVENT GALVANIC ATTACK FROM AN ELECTRICALLY CONNECTED BRONZE FITTING ACCELERATING DESTRUCTION OF LESS NOBLE UNDERWATER MATERIALS OR ZINCS. (my bold-face)No portion of the bonding system should carry an electric current for any device or any other system."After taking the Marine Electronics course this Fall, I checked the bonding system on my '86 ODay 272. The underwater thru-hulls were indeed bonded and I will disconnect them from the bonding system before launch this Spring. I don't understand why this was done by the manufacturer, but the explanation in the Marine Electronics manual which I just quoted to you convinces me to do the prudent thing and disconnect them. Again I apologize for sharing more information than you maybe wanted to know...Tom
