Further to Grounding Wind Gen'
GROUNDING vs GROUNDED:There are four main functions accomplished (on a boat) through GROUNDING:1. Safety - prevent shock hazzard (AC green gnd wire)2. Bonding - prevent corrosion (tie all immersed metals together)3. Lightning & Static Amelioration - provide a preferred path to ground for lightning.4. Counterpoise - provide an RF ground, or zero reference for electronics.None of these (4) GroundING wires are current-carrying, under NORMAL circumstances.All of these Safety or Bonding ground cables are connected directly to the Main Ground Bus.There are two main GROUNDED current-carrying conductors:5. AC Neutral (White)6. DC Negative Return (Yellow or Black)Both the AC Neutral and the DC (negative) Return are ultimately connected to ground (hence groundED) , but are NOT GroundING wires.The AC Neutral is connected to the (optional) Galvanic Isolator thence to the AC Neutral bus (at AC Panel), and finally the Main Ground Bus.,The DC Negative Return is connected to the DC Negative Bus (at DC Panel), thence the Battery Negative Post, and finally to the Main Ground Bus.The Main Ground Bus may be the Engine Block, or (preferably) a dedicated grounding terminal (bus or block) which is connected to an external ground plate.To prevent confusion, it is preferred to refer to groundED (current-carrying) conductors (numbers 5 & 6) by the term(s): AC “Neutral”, or DC “Negative” (return), and to the groundING cables as “Safety” or “Bonding” ground.To your original question: “Can the Wind-Generator’s Green Ground wire be connected to the DC Panel’s Negative Terminal?”I would much prefer this “Safety Ground” be connected directly to the Main Ground Bus (or engine block). This green ground is intended to dissipate the static charge that builds up when the turbine blades spin, and to carry the huge currents of a lightning strike. The further from the DC loads this “static” ground is connected, the less likelihood of introducing “noise” into the DC wiring. Likewise, similar reasoning applies to lightning strikes (excepting the green wire is of too small a gauge to be really effective - see below).Because the energies (DC Current & EMF/RF Pulse) of a lightning strike are so high, I would like to see the Wind-Generator Tower additionally bonded, with a large 2/0 cable. See ABYC Section(s):E-8 Alternating Current (AC) SystemsE-9 Direct Current (DC) Systems (Figures 15, 16 etc)E-4 Lightning ProtectionHope the helps,Gord
