Tom Boyd
While replacing the bilge pump float switch on my Hunter 336, I noticed that a #8 black ground wire had come loose. The wire is attached to the metal plate that I assume the keel is bolted to. It was no problem to repair, but then I started wondering exacting what it is gounding. I assume that it's grounding the electronics since it is only a #8 wire. I would expect that the engine/battery is grounded with a larger wire and now I'm wondering where that ground wire is. Does anyone know?
