Well, after three years of trying, I finally installed my new cutlass bearing. The first attempt I was hoping to pull the prop, then use a homemade bearing pusher that would push the old bearing out with the shaft in place. I failed miserably, never even got the prop off. The second attempt I went in with more conviction. I got the prop off (although with questionable methods), I fought the coupler from the shaft after a three hour battle it finally cried "UNCLE" and gave in... however, with the free shaft, I was finally able to pull the shaft out far enough to find that the rudder HAD to come off as well. I thought for sure I'd be able to sneak it by but no. So everything went back together, mission failed again. This year, I had removed the rudder last fall to fix some delamination so I had no excuse not to get it done, the only hiccup was getting the coupler off. It was again a hard fought battle and the coupler put up a good fight, but it relented and came off.
Another kudos out to Maine Sail for his articles on removing the coupler from the shaft (I've used that one twice now) and the article on removing the bearing from the strut. My guess is that none of these projects had ever been done over the life of this boat ( 1985 O'day 35) so she's a happy boat. The last thing to do was to reassemble the bearing, and driveshaft assembly, reinstall the rudder which went without a hitch and now we're ready for spashdown!
