I removed my prop for cleaning and painting with cold galvinization paint. Now it is time to relaunch . I am thinking of putting teflon grease on the shaft as it was hard to remove this time. Do most of you grease the shaft and what kind of grease??
If you are referring to the mating surface between the shaft and the prop hub ..... NOTHING should be used, these should always be assembled 'dry', never 'lubricated'.
These are *friction or 'interference' joints* (the shaft is a few 1/1000ths LARGER than the prop hub inner diameter) that depend on the friction of the 'forced together' surfaces to transmit the torque between the shaft and the prop (the torque should NOT be transmitted by the 'key' or 'sets-crews', etc.). If you apply any 'lube' the mating surfaces can/may
slip' and all the torque will be transmitted to the 'key', etc. Putting such forces on a 'key or keyway' is very BAD machine practice.
If this a tapered shaft connection, then you should consider to 'lap' the prop hub TO the shaft by using 'valve grinding or lapping compound' ..... to insure or increase the ability of the 'joint' surface to transmit the torque.
