Tim, I trust the pictures got through. Feel free to re-post to the group. The fittings are by Taco and the end rail ends are no longer in their line. Suncor, Sea Dog, Whitecap and West Marine store brand rail ends are
available on line. Are you familiar with Fisheries Supply in Seattle? They carry all but the West Marine ones. Obviously prices have gone up since we built these back in the late 1990s. On the other hand since the worth of the dollar has gone down they are
probably about the same. The most difficult part was drilling through the cabin top. Inside the cabin the machine screws are secured with fender washers and lock-nuts. the problem with through bolting on the cabin top is compression. I drilled oversize and
filled with them with epoxy and colloidal silica then re-drilled through that.
Position the rails where you want them. Drill through the cabin top and assemble the rail where you want it to be. Remove the rail and re-drill half the the holes at a time, i.e. inboard holes on the uprights and outer
holes on the rail ends. That way you can use the unfilled holes to get the position right when you bolt through the filled core. I believe I used a 3/4" hole saw to drill the oversize holes. Drilling will be easy after you get through the outer layer of glass.
Don't go through the inner layer of glass when you start to get more resistance you'll know you've hit it.
Caution on this as epoxy heats up as it kicks. Put a piece of tape on the underside of the hole and and drop a few drops of epoxy on this from topside and let it harden. If you omit this step and put to much epoxy in
it will heat up as it kicks, the tape will fall off from the heat and the epoxy will drain through onto whatever happens to be underneath. Hopefully not a settee cushion! When filling the holes don't be tempted to put to much epoxy in. Maybe a 1/4 of and
inch at a time and let it kick. Putting to much in at one time will cause the epoxy to foam as it cures. It sounds more complicated than it is. Just somewhat tedious. Probably not a a project for a cold Alaskan winter.The interior hand rails were kept in the same position but re-secured with machine screws into T-nuts. the holes were drilled oversize, T nuts inserted flat side down with a bit of epoxy to allow them to get a grip and
allowed to set. It will go easier if use longer machine screws than you need as you are setting this up. Coat them with soap so the epoxy won't stick to the threads. After the epoxy has kicked remove the longer screws and fasten the rail in place with shorter
screws. These too should have soap on the threads and should go maybe an inch bast the end of the T nut. Fill the holes as previously discussed and sand flush when done.I got to be really good with epoxy over the years. Lyric had a lot of work done with it! WaltP.S. I'm well underway into buying a 22 foot Marlin cuddy cabin fishing boat. Although I'm going to a powerboat at the wife's urging I'll always consider myself a sailor and more importantly, a Vega sailor!
AlbinVega@yahoogroups.com AlbinVega@yahoogroups.com on behalf of alaskaflyfish@... [AlbinVega]
Sent: Wednesday, January 10, 2018 1:08 PM
To:
Subject: [AlbinVega] Grab rails
Has anybody replaced their exterior grab rails with homemade stainless steel rails? Mine are kind of thinned out from years of sanding. I cannot get teak (or any wood) here in Alaska (except red oak) at a reasonable price to make new ones but I can get 1
inch s/s tubing and fittings sent via mail. Any comments to functionality and looks?
