I would recommend that instead of GPSNav-X that you consider MacENC so that you can use both Raster AND digital ENC (S57) charting.
Ive been using the following 'ages' (many many thousands of sea miles) and although my Mac Navigation is now mostly 'backup' it still outperforms the 'best' chartplotter or integrated nav. systems available. A Mac integrated with the below listed components will be an 'outstanding' Nav system and can also include AIS; the system is elegant and will be 'head and shoulders' above a normally 'clunky' WinDoze system.
I keep my Mac on the nav. station (bolted down!!), but the only downside with PC navigation is that it requires walking back and forth from the helm station --- about the only disadvantage of such a system. I use an old Garmin-48 mounted at the helm station and power it with a combo Garmin 'data cable' + power cord. Garmin still uses the ancient 'serial port' connections for data transfer so the data cable must terminate into a 'multiport USB to serial port adapter (see below). Get a USB adapter with 'multiport' connnections. The USB--> serial connector plugs directly to any of the Macs USB ports. You may need a long serial cable to make a 'long run' connection from the helm to the Nav station.
I power the Mac with a 12v--->19v step up transformer (less power draw than using a single purpose inverter and Mac "Power Brick") - see below. Charts (Raster AND Electronic ENC S57) can be downloaded FREE. You can download a FREE demo MacENC for trial purposes - see below.
If you use a multiport USB adapter you can easily add AIS (see below for equipment) which will overlay on both the raster or ENC charting when run using MacENC software. You can get a powered antenna 'splitter' so that you can use your VHF antenna to also supply signal to the AIS receiver - see below.
Cautions with a Mac onboard ---- Keep the Mac ON at all times (not 'sleep' mode) to prevent condensation on/in the internal circuits, especially during changeable dewpoint conditions. If at sea be sure to cover the Mac (keyboard and 'ports') with Saran or other clear plastic film) to prevent the migration of microscopic airborne salt crystals INTO the mac --- important!!!. During lightning storms, put the mac into the oven (Farraday Cage to protect from RF components of lightning that can 'surge' the IC circuits even with the computer off).
Software:
http://www.gpsnavx.com
http://www.gpsnavx.com/MacENC/ ---- download a FREE demo version.
FREE charts ----
BTW both (raster and ENC charts ) charting systems for the USA can be downloaded
FREE:
http://www.nauticalcharts.noaa.gov/mcd/Raster/index.htm
http://www.nauticalcharts.noaa.gov/mcd/enc/index.htm
Internet forum for Navigation, etc. for MACINTOSH
http://www.macsailing.net/fbb/index.php
POWER SUPPLY for Macintosh
12-->19v 'step-up' power supply for Mac :
http://www.mikegyver.com/Store/index.html
HIgh speed USB --> serial adapter (multi-port) http://www.usb-ware.com/usb-twin-serial-adapter-usa-28x.htm
AIS receiver ----
http://www.milltechmarine.com/Smart-Radio-SR161-AIS-Receiver_p_167.html
Antenna splitter VHF-AIS:
http://www.milltechmarine.com/Antenna-Splitters_c_19.html
hope this helps.
