GPS Serial to USB
56
Oday 27 Ottawa,Il
Down loaded Seaclear and NOAA charts to new laptop that has no serial ports. Gps that came with the boat is a Garmin 72 with a serial cable. Has anyone came up a proven adapter that works and if so, what is it? Thanks Ron
Apr 1, 2004
186
Catalina 34 Herring Bay Chesapeake, MD
Ron,
The "Purple One" is a serial to USB converter, see the attached link.
http://pfranc.com/cgi-bin/P/USB_G4
It is the only one that I found that would work completely with my three Garmin hand held GPSs.
I have no interest in this company, I only wanted a connector that would allow to interface with the USB posts on my many different PCs.
Good Luck,
Steve
Aug 20, 2006
220
Hunter 33_77-83 Yucatan, Mexico
I have a Garmin at the pedestal connected to a laptop at the "nav station"
After trying a few and according to garmin's tech support, apparently the Radio Shack unit works the best. Got it and installed the driver on laptop, all is working perfect after almost 2 yrs. Knocking on wood....
good luck
cheers
Bob
Sundance Sundance 20 Weekender Ninette, Manitoba, Canada
I used the Radio Shack adapter as well
no problems. I downloaded all my old data from my old gps that was serial only, the uploaded to my new Garmin 76cx using the USB. No problems what so ever. I can't remember exactly but the cost was only $16 or so, definately not more than $30, and definately worth it for not having to re-enter all those waypoints all over again.
My adapter was a cable about 6' long.
143
Hunter 33 Santa Barbara
USB to Serial Adapter
I think I got a 'PDA Adapter' sometime ago for this purpose (USB-Serial).
Michael
BarryL
May 21, 2004
1,126
Hi,
Another option is to spend $25 for a USB GPS receiver. I bought one and it works great with Seaclear. And you now have a backup GPS as well.
Barry
Feb 24, 2005
56
Oday 27 Ottawa,Il
$25 dollars?
Barry, what is this usp gps for $25 dollars and where did you get it? This really sounds like the answer. thahks Ron
Sep 26, 2008
566
- - Noank CT.
Radio Schack
Sells a serial pin to usb adapter. Cost was around 40 dollars. Worked well with my JRC antenna
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
Reciever
I found a USB GPS reciever at Tiger.com 3 years ago, but it was more like $75 back than. That was after I wasted $35 on an adapter for my Garmin that did not work. The unit from Tiger works great.
