Apperantly in our rush to ipod, andorid and G5 technology we forgot that there is a limit to how closely you can stack the frequencies together and still get everything to work.
LightSquared is setting up a ground based high power next gen link for all you folks that are using your PDAs while doing what ever it is you do all day. Unfortunatly the band (L-band) they are going to use at 1000 watt level is right next to the band that GPS uses (at micro watt levels). Bleed over is expected which means NO GPS. LightSquared is doing this nationally (US) so all you non-US folks have nothing to fear.
Call the FCC and your congressman, LightSquared is using the time tested method of calling GPS something else to hide the criticality of what they are doing. In this case GPS becomes RNSS (radio navigation satellite service)
http://en.wikipedia.org/wiki/LightSquared
