We have been over this "ground" literally so many times. The GPS charting over ground will always be more accurate then a speed sensor reading from a rotary wheel. There are far too many variables in marine growth & water slipping over the wheel from different directions, etc. to make the speed reading inaccurate on a wheel sensor. The least bit of growth on that wheel restructs its movement, & then it dosesn't work properly. I, & many others on this forum have also proved that you can indeed sail a boat faster then its theoretical hull speed! If you are sailing dead downwind, with the tide helping you move your boat along with full sail, any sailboat can move faster then then its theoretical length of its hull, waterline length, etc. I guess Mort just hasn't hit the right wave yet or sail combination & proper trim. Too bad. It's a rush when you get it right. I even have digital photos that I've taken of my GPS & speed readouts to prove that I've gotten well over 7.2 knots on my C 30, & I wasn't even trying that hard. I hope there are other sailors of C 30's & 27's who can back me up on this one. Cheers.
