gps antenna
mortyd
Dec 11, 2004
952
Catalina 30 easy living
anyone out there know where the best place to mount a gramin gps satellite antenna on a catalina 30, walk thru?
Jun 3, 2004
145
Catalina 27 Stockton CA
Mount it outside...
Although I'd bet it'd work almost anywhere, the key is to mount it as far from metal that'd interfere with it's ability to receive the transmissions from the GPS satellites as possible. Best is outside the pyramid of the stays & shrouds, like on a radar mast, or a stern pulpit. I once had an early Garmin handheld. I don't remember the model, as I returned it to West Marine, and bought a Magellan, which at the time worked marginally better -- now I use both manufacturers. It wouldn't locate itself unless I stood up on the transom, and held it at arm's length. Not really practical for ongoing VMG calcs when you're beating into the wind that's blowing 25 knots...
Catalina 320 Dana Point
My Garmin GPS III (~10 years old) works
fine in the cabin on port side with internal ant. except when heeling to port a lot. Used some laptops with internal receivers which would function in an auto but not at all in a truck with diamond plate on roof. As Peter has said outside is best and most end up on a stern pulpit rail on side (not over transom) to get them free of most overhead obstructions. Used some Garmin GPS-16 receiver/ant.(like a hockey puck) with laptops using magnetic mounts and their function was very good even mounted to vertical surfaces.
