So, to add to the puzzlement, I just took out my NSS8 that had been lightning damaged last summer. As far as we know the NMEA interface was damaged but everything else on it was fine. I waited for good GPS fix with an accurate location, then went into Pages -> Tools -> Satellites and saw that where I live it's apparently 6:23 PM on August 17th 2099.
It is correct that it's 6:23 PM here, but unless I lost track of time I don't think it's 2099.
@Slider is that the same place that you see dashes for the time? One other thing you can check to confirm is that you're not in Simulate mode. It seems that simulate provides a position but not time. If you're in that satellite screen the GPS source on the bottom right should be something like NR8 iGPS (this device), not Simulate.
I know there is a GPS clock rollover coming up that could cause confusion on some GPS devices, but I thought that was older devices, and not until next week. I wonder why both of ours are acting strangely. What software version do you have? Mine is 3.0.
