GPS and Depth sounder.
bchasc
Jul 10, 2015
13
Catalina 25 Kingston, WA
Greetings all,
I need your expertise again...I am going to install a GPS and Depth sounder in my Capri 22. Question is where should I install an in-hull transducer?
As always, Thank you for your help.
Bruce
Catalina 310 278 Lyndeborough NH
Not over the wing keel!
I tried several locations: just behind the cooler location, in front of the port-a-potty in the bow, on the port side.
They all do work. The bow location gives more noise in the signal, but otherwise it is fine.
Most important to bring down to bare fiberglass and use thickened epoxy with no air bubbles trapped in it.
If you don't like the position,you can always pop the transducer off and move it to another location.
