If you use gelcoat without wax for the final coat, you will have to apply PVA (polyvinyl alcohol) on top in order for it to cure properly (tack free). If the gelcoat has wax in it in, you do not have to apply PVA. If you apply multiple coats of gelcoat with wax, the wax has to be removed after curing before subsequent coats are applied.
