Got the generator running
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
Hi all,
It’s taken a while to finally get the right gauges and senders for our diesel generator (most places wouldn’t help for numerous reasons) and I fired it up. Well it ran for two minutes then quit and the engine compartment was full of exhaust. I aired it out and got the fire/CO detector quieted then started to investigate. There was a scattering of carbon leading back to the Hx/mixer elbow.
I got busy draining the antifreeze coolant and PB blaster on the flange bolts. After some effort I got the elbow off, it looked fine. The flange on the Hx however had eroded just beside the flange gasket. This Hx was new 2014 but shows the same erosion of metal that had happened to the previous one. Only exhaust gases run through this section with water injected further along in the elbow. What would cause this type of erosion and how can I fix it?
Here’s the picture. The arrow points behind the paper gasket where the metal is thin.
21AD0DF9-0183-48B7-95CF-0E481212F9AC.jpegB2F5881C-D5CC-446E-BEA8-F429056E2A18.jpeg073B354E-D8FB-4D4C-A5EC-0EE4F442BA06.jpeg
917
I'm guessing here.
1. Poor quality casting.
2. Needs zincs replaced more often. It's aluminum correct?
Sure looks like a lot of damage.
Yes but that is what happens when a boat is used a lot cruising.
How was the HE zinc? I know mine was gone after a couple of years. Got lucky that the HE passed the pressure test. Now it’s on the 6 month check list.
capta
Jun 4, 2009
4,958
What genset is this? Color looks to be Onan, but I don't recognize the model.
I should think corrosion like that would require some liquid from time to time. You said it was a dry section of the system? Could your vented loop be allowing water to drip into this junction on shut down, just to have the heat boil it away leaving little or no indication it was there.
Oct 2, 2008
3,811
The red arrow is the plug with raw water from the Hx above, no zinc. The yellow is coolant drain for Hx, no zinc. The green shows exhaust flow towards the mixer before any liquids are introduced, no zinc. Kohler genset powered by a Perkins 4.108.
dLj
Mar 23, 2017
4,486
I'm trying to understand. I've edited your last image - is this correct? Also, you wouldn't use zinc to protect aluminum, you'd have to go to a magnesium/zinc alloy, zinc is too close to aluminum on the EMF scale. Secondly, this is a dry area of the system, a sacrificial anode wouldn't work anyway as you need the part you are protecting and the anode to be in the same electrolyte (water/soil/that sort). But this is a dry section of the system. High temperature corrosion can occur without liquid being present. @All U Get - I'm heading off on a work trip in a couple hours so won't be able to monitor this thread for awhile. But if you can please look at the image below and clarify for me that this is correct, that would be useful. Also, and I know this is difficult, if you can take better photos of where the corrosion is taking place and post them, that would help a lot. You will have to figure out how to get lighting into that area with the corrosion to be able to see it better. I'll try to get back to you when I've time.
dj
RitSim
Jan 29, 2018
457
Beneteau 411 Branford
In addition to other suggestions above, it looks like a gasket failure. There should be no flow path across the gasket surface. Could be the flange has pits or the flanges are not flat and parallel. The gasket must be evenly loaded.
Oct 2, 2008
3,811
After looking closer, the gasket was intact with the leak just behind the flange. The skinny arrow is pointing to where the corrosion let out the gasses.
Is there a way to rebuild this area or get it machined?
JamesG161
Feb 14, 2014
7,832
Hunter 430 Waveland, MS
The Perkins engine should be protected by a Zinc.
My Kohler genset is powered by a 16hp Yanmar. The Yanmar has a pencil Zinc that has to be changed every 500 hour on the genset.
Jim...
Oct 2, 2008
3,811
I’m curious as to where a zinc should be, in the coolant or raw water. My problem is in the dry area of the exhaust. I just talked with a cruise who said he didn’t have a zinc on his Yanmar engine.
The Hx is a Bowman PE 180.
I have not found a zinc on the engine block, but now you will have me looking... my zinc was in the Heat Exchanger. Or it was supposed to be. By the time I found it and got the Heat Exchanger off so I could remove the zinc the zinc was no more.
Now I have a new maintenance item on the schedule.
Likes: JamesG161
JamesG161
Feb 14, 2014
7,832
He better look!
The Previous Owner had 1200 hrs on the Genset Yanmar. The Zinc was totally gone and he never changed it.
The Yanmar Zinc is tough to find and change. One of those "stand on your head" spots. Mine had the original White paint on it.
I got lucky for sure.
Jim...
JamesG161
Feb 14, 2014
7,832
Nor will you find one.
The raw water Zinc does the protection.
Jim...
PS: My Volvo Penta [by Perkins] is protected by my shaft Zinc.
Jun 14, 2010
2,381
Jim...
The 2 Volvo Pentas that I’ve owned have been isolated electrically from the the boat‘s 12v system. The momentary connections are made by relay for starter and stop solenoid, and are otherwise disconnected.
Likes: JamesG161
Nov 6, 2006
10,117
All U Get.. if ya take the part to a good machine shop, they should be able to repair the part .. They can thicken it up where it failed.. There is a process, "electroless nickel plating" that is not too expensive that may stop this future failure after the repair..
Likes: All U Get
Oct 2, 2008
3,811
Here’s a new one! I’m going to check locally to see if I can get mine rebuilt, otherwise my silver bullet is going to have more toothmarks.
JamesG161
Feb 14, 2014
7,832
If you look at the rear view picture of your Bowman link, my bet is that "plug" is the pencil Zinc.
You might check your exchanger for that plug.;)
Jim...
Jun 14, 2010
2,381
I have said that a few times in SBO, and they all didn't believe me. No stray currents allowed to my Volvo Penta.
Jim...
Yes, and V-P also isolates the drive shaft (or leg) components from the engine block. The only connection is through the cooling water, and that's a closed system that's disconnected by the antisiphon loop when the engine isn't running (but it has no 12v connection while running except the moments when you start or stop it).
