Got Stuck....
11,772
Yesterday I got stuck in the rear lazarette of a customers boat. I am replacing his steering system and had to terminate and connect the new steering cables to the radial drive. Other than taking half the cabin apart, which would have meant hours of labor, and then tedious matching of LOTS of drilled out bungs, I managed to squeak myself into the compartment.
This is an Ericson 32 and this compartment is SMALL and loaded with hoses and thru-hulls for the cockpit and LPG system. This locker is only HALF the rear hump seat because the other half is the LPG locker..
Going in, while not easy, was doable. It was getting my head in that was the hard part. Once in I could rearrange my legs and lay sideways to terminate the new steering cables. Certianly not very comfortable but it could be done.
I brought all the tools I needed, which was good, and set my cell phone right on top of the "hump seat". While in there working I heard the "zip" sound of my cell phone sliding down the hump.. Doh'.. It slid just out of reach...
I was in there for about 30-40 minutes working and once finished tried to get out. No go.
Rearrange legs, try again, no go.. This went on for well over 20 minutes...:cussing:No matter what I did I could not get my head out. Going in I could see how much I needed for room but coming out I was blind to it. I could not replicate the leg position I use to get in there.
I finally decided to try a feet first escape. Got myself turned around shot my feet to the sky and began climbing out upside down. Once I got beyond my knees I flipped 180 and managed to shimmy out on my belly. This was NOT without multiple "hose clamp bites"....
Lessons:
#1 Make sure your cell phone is secure!! I thought mine was....
#2 DO NOT panic... I am not at all claustrophobic so was able to keep a cool head and think about it. I was smart enough & calm enough to NOT try and put myself in a position that could not be undone.
#3 At least bring every tool you might need. You don't want to get stuck and still not have completed the job you went in to do..
#4 Go on a diet!!!!:D:D
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
Ditto
I had some thing like that happen to me but not as bad,my problem was my back just can't do the things I it use to do with out extreme pain and when it happen to me I was head first up side down and so getting dizzy while being stuck up side down hot as all hell.
I did panic for a second than just wiggled out back wards with the pain running down my legs,oh if only my body was younger again without the having a bad back.
Nick
Sep 2, 2011
1,041
Hunter 27 Cherubini Alum Creek State Park
Shudder!
I'm slightly claustrophobic. sounds like my worst nightmare. I once went into a State Park cave, and down a side tunnel. It kept narrowing until I could no longer go forward, or turn around. I had to slither backwards 50 yds to get out.
I just plain won't go into very small spaces.
Glad you're out safely, and unharmed.
Jan 14, 2011
243
tanzer tanzer 28 bathurst nb
a small kid works well in those hole! my kids are just old enough to understand the job at hand but small enuf to fit anywhere!
Apr 22, 2011
979
Hunter 27 Pecan Grove, Oriental, NC
I,m curious who you would have called if you could have reached your cell phone. One option, calling 911 would bring expert help but possible reporting on the 6 o'clock news. Calling a friend might work but would the endless kidding be worth it. Calling the wife, last resort, would mean a 20 minute lecture before she called 911, the press, and all your friends.
Nov 6, 2006
10,253
I have had nightmares about getting caught in the hole in the H-34 starboard cockpit locker.When I go in, I securely tie the cover up because I could see in my mind, the cover slamming shut and the little hasp clicking down to secure it.. I put cell phone in there on a secure ledge .. Still causes some concern
Helped a friend get out of his lazarette a few weeks back.. he was upside down and couldn't get enough traction and clearance to get out.. I happened to be on a boat a couple of slips down and heard the bumping and magic incantations.
gpd955
Feb 22, 2006
1,164
Catalina 310 Cape May, NJ
Will this be featured in the YouTube series of videos?? :)
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
I am with you, Kloudie- every time I go down into that ever tighter hole I think of the cover slamming down and the catch flipping down. I always put something big like a fender in the "tray" at the shallow end of the locker. My resolve to lose 20 pounds is always at its highest as I am worming my way back out of that hole.
-na -NA Anywhere USA
Maine Sail is absoultely correct if stuck, calm down and think what you need to get out. Never try going into a small hole if you are alone. Called safety. I have been stuck, hyperventalated and went bannannas . Calmed down and figured out how to get out. I then hired a smaller employee after training him. One thing to mention, never go into this situation when it is very hot without any ventilation or you could really get in trouble.
crazy dave condon
Dec 29, 2008
806
Treworgy 65' LOA Custom Steel Pilothouse Staysail Ketch St. Croix, Virgin Islands
Amen to the diet part! I keep telling myself I need to lose weight so I can fit better in the engine room and reach things I need to. I find I can't breath while bent over. So far, I am not having much luck.
Obviously, Maine isn't too concerned about friends finding out - after all, he posted it on here voluntarily...
Nov 6, 2006
10,253
Laughing, Richard.. Yes indeed I get the inspiration for weight loss every time I have to get in there..
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Mechanical fingers.....
Lessons:
Dont leave home with out them .......i find this amuseing in relation to my working on my boat and my boat buddys boat ...his is 5 ft longer than mine and i move around good in his but a little tight in mine......
regards
woody
1,517
Jboat J24 commack
I backed into the anchor locker and got stuck and had to really ponder how i had gotten IN to get back OUT as i was darn sure not gonna cutup the boat again
Dec 2, 1999
15,184
MS: You mentioned taking all of the tools that you may need with you. Maybe you missed an important one. Ms Hall would recommend SuperLube Teflon grease, I would have to suggest that KY jelly may have been appropriate.
Bob J.
Apr 14, 2009
775
Sabre 28 NH
I can see the news now, marine repairman cut out of fiberglass boat, full details at 11:00.
#5 - hope you don't get cramps in your hamstring or calf. :):):)
Years ago I bought an old used Dodge Dart, one with the venerable slant six engine. Loved that car.
I was putting in speakers for the stereo in the flat space behind the back seat. My then-five year old daughter climbed in the trunk and stuck her head up into one of the holes. It took us hours to get her out without strangling her! Sometimes ya can get in, but getting out is a whole 'nother job.
Glad you're safe. Those Ericson 32s have some really tight spaces. A friend had one, and the ONLY good access I really was to the port side of the M25 engine when I replaced his old alternator bracket for him.
Ross
Jun 15, 2004
14,693
Being only five and a half feet tall and reasonably lean get stuck is rarely a problem for me. But it has happened and I wonder if they will have to cut me or the house up to get me out.
Phil Herring
Alien
Mar 25, 1997
4,924
- - Bainbridge Island
Stu, I really like the image of you driving around the Bay Area in a Dodge Dart. :)
And heritage, really? 20 minutes? You must have a very forgiving spouse.
Maine, this post made my day.
