that is somewhat intermitant but is constant when thottling up and running at high RMP in gear. Doesn't happen in neutral and doesn't happen when running at low RPM. First I thought it was mechanical, that something was banging around involving the shaft or the folding prop because the sound seemed to be coming from somewhere lower and aft of the engine. Had the prop checked when I had the hull scrubbed and I examined the shaft/coupling under power and see no misalignment or anything loose. Now I think the sound appears to be coming from the exhaust discharge. Yanmar 4JHE. No other symptoms. Engine moves the boat great and runs well and smooth. Could this be caused by some problem in the exhaust system something related to the muffler? I ran the engine about 50 hours before the symptom developed. I am not yet educated on exhaust systems, mixing elbows etc., so I am just guessing on the muffler issue.Scott
