This season I replaced my 3 blade fixed prop with a Gori 3 blade folding prop on my Hunter 36. It has exceeded all expectations. The original prop was undersized for the boat. Our cruising range has increased significantly. Under sail we have picked up a Kt due to the folding prop. Prop walk has been elimimated, though sometimes that is not a good thing. Under power I just had to run up the Potomac in 20-25 Kts apparent on the nose against the current and swells. The boat maintained 6 KTs SOG powering thru the swells. Quite impressive. The prop blades pivot individually so they turn 180 degrees when going in reverse. The prop has an overdrive position for increased thrust by maintaining the blades in this reverse position while in foward gear. This also results in reduced fuel consumption. Just wanted to share my Gori experience.
