Tim Dranttel
I've recently purchased an 86 Cat 30. When I removed the mainsail to clean it and repair some minor things I notice that the gooseneck to boom connection had some play in it. Thinking that there was a large nut on the other side of the boom-end plate I attempted to remove the boom from the goose neck. I undid the four screws around the outside of the boom thinking that surely these are what is holding the boom-end plate to the boom. With the four screws out I could not remove the end plate with light prying and some lube. With both the boom and the end plate being aluminum I am leary of getting too aggresive. First off do I have a problem or is some play (1/2") where the large goose neck pin fits into the boom normal? If not what to do?
