gooseneck rivets
Hunter 23.5 SD
Putting my 26 hunter(97) away for the season. When taking the boom off noticed a very loose rivet that holds the gooseneck to the mast. In fact could pull it out if tried hard enough. How does one re rivet this. Appears to me to be very serious condition.
Paul F
Jun 3, 2004
827
Hunter 1980 - 33 Bradenton
Post a picture if you can. If possible replace the rivet with a SS bolt. If it goes into a blind area in the boom or mast maybe you can drill out the old rivet and replace with a new one.
Jun 28, 2009
312
hunter 23 Lake Hefner
Drill it out, you may need to use a larger size rivet if it erroded any of the mast and use a SS pop rivet. That'd be my suggestion.
