Gooseneck connection
Isail
Mar 10, 2014
1
Hunter 18.5 Longboat Harbour
Greetings; I was given a Hunter 18.5 that needs a lot of work. At present, I'm trying to rig the main but can't figure out how it's supposed to hookup at the gooseneck. If any other owners of an 18.5 would have a photo or diagram they could share with me I'd be very grateful. Thanks & good sailing, Jim Owen (jimowenoci@aol.com)
Mar 20, 2012
3,983
or, you could share a photo of what you have for a gooseneck fitting on the mast and the boom end attachment so we may be able to tell you what your missing... :D
-na -NA Anywhere USA
For reference, look under the column for boat information and pull up the 18.5 which has the owners manual. In addition you will find photos there.
At the gooseneck, you should see a curved U with hooks on the two ends. Simply put the gromment attached to the hook. Hope this helps you sir
