good interior cleaner
Nando
Aug 27, 2019
10
Catalina 27 Pensacola
i recently bought a 27 ft Catalina that has sat for over 7 years. the interior has moldy stains and old pInt that is chipped in spots. I want to clean it as best possible and need advice on a good cleaner stain remover. thanks
Dec 27, 2012
587
Precision Precision 28 St Augustine
I recommend a product called Folex for fabric cushions and your liner if it has fabric over the fiberglass. It’s a spray and wipe application. I’ve used it with great results. It can be purchased at Home Depot, Ace hardware and many other places. It’s found in with the home cleaning supplies.
Likes: ULost
Nando
Aug 27, 2019
10
thanks. how about something for the walls and floor.
Dec 27, 2012
587
If the walls are fabric or some other non fiberglass surface then Folex is good. As far as the floor area I sometimes remove my bilge covers and scrub the floor with soft scrub. Let it sit a few minutes and hose it into the bilge.
Likes: Nando
Mar 2, 2019
671
Oday 25 Milwaukee
Simple Green has been my go to for pretty much everything boat related . Safe to use pretty much anywhere on the boat and doesn't hurt the environment . We use it in an industrial environment at work and at home .
We don't need gloves and it not hard to breath.
Nando
Aug 27, 2019
10
thanks
May 7, 2012
1,615
Hunter e33 Maple Bay, BC
Obviously opinions and experiences differ greatly regarding this product. All I can say is make sure you first test it on an inconspicuous area before large scale use
I just spent a day cleaning my long neglected cruiser. A lot of time was spent scrubbing mildew/mold of vinyl surfaces. I used Mr Clean and a scrub brush. I wish I’d read this thread first - it was a lot of elbow grease which I don’t have vast reserves of!
dmax
Jul 29, 2018
1,323
Telstar 28 Buzzards Bay
In general, always work up in aggressiveness of the cleaner, making sure you don't cause more harm than good. Dish soap is a good first level, followed by a Citrus Cleaner (I like Citrus-Solv). A scrub brush can then be added - nylon first and then a brass wire brush if the surface can handle it. If that doesn't work, you can try some Bar Keepers Friend which is mildly abrasive and gets rid of some stains (rust). You can then try solvents like alcohol and acetone, the latter will remove most finishes. If mild cleaning and solvents don't work, you probably then need to remove a layer from the surface with the appropriate abrasive: brass wool, 3M pads, wet sandpaper, rubbing/polishing compound etc.
Wood can be restored pretty easily by cleaning, sanding down to good wood (careful with veneers) and refinishing with oil or varnish. For the painted surfaces, your best bet would be to clean them up, scrape any loose paint off, feather out the chips as best possible and repaint. You can use a good quality Latex Bathroom paint in the interior - easy and cheap.
Likes: Hello Below
I have found BKF also works very well at removing tannin stains. So if you have brown stains from leaves that sat in your cockpit or the Chesapeake smile or Bayou Brim on your bow... BKF is a good go-to.
Sep 24, 2018
4,475
Catalina 30 MKIII Chicago
Search the forums for Formula B. There's a ton of info in some of those threads. Others have also recommended Wet N Forget to me. I'm hoping to use it tomorrow
