would 2 golf cart batteries better than one deep cycle battery i now that they are only 6 volts that is why i'm using two to make 12 volts thank's in avance bob l
Bob,Current and prevaling wisdow says that golf cart batteries are better than the marine deep cycle in my opinion. Some of us use them. They have high re-cycle rates and provide large amps. I have 4 T105's in series and parrelled to supply 450 amp/hrs of that, I can use 225 amp/hrs which is 50% of capacity. Big thing is they are inexpensive compared to same rating in marine deep cycle batteries.Jim S/V Java
A major consideration for me would be the difficulty of moving a single large 12-volt battery. Frankly, even the 6-volts are big enough!My first set of golf carts were T-105s (4 batteries) and they lasted for years. I'd have to look at my records but I think it was about 9 years. I replaced them with "heavy duty" golf carts rated at 245Ah per pair, thats 490Ah for two pair. Something to consider if you're looking for a tad bit more capacity. Cost was slightly more per Ah than for the T-105s.
I use 4 T-105 Trojans and feel that they are better than 4 12V in parallel. The big issue is that I feel that they are a higher quality battery that is accepted industry-wide for golf carts, floor maintenance, and a variety of other deep cycle applications.If 12V deep cycle batteries were better, don't you think the golf cart industry would use them?
