There are other alternatives
If you are assigned someplace where you do not get a housing allowance or it is reduced, you could put the boat in charter and it might very well pay for itself. There are potential problems and pitfalls with chartering companies but it is at least a theoretical option. Someone here may know of a good one in SD. You could probably reserve the boat for yourself at times when you could use it.It sounds to me like your assignment would likely be at a major population center so the chartering idea might work out even if you have to get an apartment in Nevada. There must be military flights to SD from just about anywhere you might end up and you could catch a "hop".As to trucking, you can transport a boat considerably over 40 feet. I know of a 45 footer that was trucked here from Floida. It was about $5k as I recall. That is a whole nuther subject though. I think it was $3.5k from here to SD for a 34 footer.Doesn't the government pay a relocation allowance? I do not know but that might cover moving it. Probably a good idea to ask your CO.
