Going Solar
Squidd
Sep 26, 2011
890
AMF Alcort Paceship PY26 Washburn Wi. Apostle Islands
Leaning more and more that way..
Got my eye on an 80 watt Bosch Monocrystal Panel with a 10 watt Dual Battery PWM controler that should monitor each battery seperate...
Then that leaves me the option of adding another 80 watt down the road if I need...
Only a few bucks more than the 40 watt panel, but the 40s a bit smaller so may be easier to store on boat...But I'm thinking I may want the "recovery" of the 80 watt in case I go out more often than last season...
Maybe I should just get the 100 watt roll up and be done with it...
Sumner
Jan 31, 2009
5,254
....Got my eye on an 80 watt Bosch Monocrystal Panel with a 10 watt Dual Battery PWM controler that should monitor each battery seperate....................Maybe I should just get the 100 watt roll up and be done with it...
Is there a reason you want to keep the batteries separate? If you still want two 12 volt tie them together and leave them together in use and while charging. They will last longer and charge better. I'd still go with two 6 volt for what you are doing, but that is just me.
If you can swing a larger panel go for it. If you ever decide to get a fridge (one of the best things we did) you'll be glad you have a larger panel,
Sum
[FONT=Arial, sans-serif]============================[/FONT]
Our Endeavour 37
Our MacGregor 26-S Pages
Our Trips to Utah, Idaho, Canada, Florida
Mac-Venture Links
Squidd
Sep 26, 2011
890
Thats what I do now, have them tied together with the battery switch on 1&2 for both charging and running. Pull start OB.
So you say I get more usable amps tied together? The charger/controller meters each battery seperate or can be set toread one.
Sumner
Jan 31, 2009
5,254
If you have them on both then that is good, but if wired ....
.....like above they would last longer and be used and charged more uniformly and wouldn't be drawn down like if you used one and then the other. You could buy a less expensive controller and the controller would be putting all of the available amps to best use into the one bank.
Using the both setting on the switch is better than using them one at a time, but wiring them like above is better yet.
Put the positive output to the switch on say the #1 terminal and from there to the load buss. Now the switch is just an on off switch.
If your outboard has a charging circuit take the lead from it to the positive on the one battery or to where it attaches to the switch. Either way fuse it as close to the battery as possible. This will keep the outboard tied to a battery and you don't have to worry about frying the charging circuit on it.
The two 6 volt batteries would cost about the same as the 12 volts do, but give you more amp/hours for the same buck. You would wire them in series....
.... like above on the right and run the outboard to them the same way if it is elect. start. Run them to your present switch but again just use the one post for an on/off switch.
The 6 volt should last longer than the 12 volt as they are more of a 'true' deep charge battery vs. the 12 volt that are a compromise between deep charge and starting.
If for some reason the batteries ever went dead you can pull start the outboard can't you?
Also if you put a cheap digital voltmeter in the system you could monitor the batteries pretty well,
Sum
Our Endeavour 37
Mac-Venture Links
Squidd
Sep 26, 2011
890
OK, this is starting to make a little sense now (I think)...
The boat is actually set up with three battery "mounts"...two low and centered over keel and the third up on starboard lazarette shelf to help offset port OB motor and tank.
So I'm thinking either a pair of 6vs series or a pair of 12vs Parrallel down low (on #1 post) and a third 12vDC on the shelf (post2) as true "reserve battery"
Dual controller can charge main "house bank" (80% output) and maintain "reserve battery" (20% output)...then when one tops off put 100% in the remaining bank...
Controler also has outlet for optional digital display panel that can program the controler outputs and read the individual bank state of charge...that should be cool...
I'll have to shop around for some 6 volt Batteries (deep cycle??golf cart??) not real familer with whats available out there...
Sumner
Jan 31, 2009
5,254
....Dual controller can charge main "house bank" (80% output) and maintain "reserve battery" (20% output)...then when one tops off put 100% in the remaining bank.....
That would work or go with this....
http://www.defender.com/product.jsp?path=-1|328|51495|299265&id=750182
.... ACR (combiner) between them. It will essentially do what the charger you are thinking of getting will do. That is what we are doing on the Endeavour with a large four 6 volt battery house bank and a separate 12 volt start battery.
The advantage I see is if down the road you increase the solar array for any reason you could change to any charge controller or if you wanted to change at some point or now from a PWM controller to a MPPT controller. What ever you do the ACR will keep both banks up regardless of the charger type or if the charge is coming from something else like the outboard.
Also for now maybe don't put that third battery in there and start using up its life if you don't really need it for your current needs. Buy it and have it fresh if you ever need it and then add the ARC at that time.
You do want, if at all possible, the other two batteries to be of the same type, manufacture, and age. Our two 12 volt batteries in the Mac are the same type/manufacture but about 4 months apart and if I check voltages on them separately they vary by a couple tenths. We do run them together all the time though.
Lots of combinations,
Sum
Our Endeavour 37
Mac-Venture Links
Oct 17, 2011
2,809
Ericson 29 Southport..
Here's a whole different thought, (mine generally are). I had the same problem on the hill last year, when some thoughtless ahole kept unplugging my boat, to do some work on his. I got a three into one plug adapter, plugged my drop cord, (I was only needing 110V/15 amps by the way), into one of the three way outlets, letting the other two remain free, for future users of the receptacle, TIE WRAPPED my plug into its socket, and tie wrapped the three way to the pedestal. So if someone were inclined to unplug it, they would have to get the pocket knife out to cut it free, BUT....there was no need to do that, as I had left the two open plugs. The issue was resolved.
Plus a little "counseling" with the turkey that unplugged my boat, and left it that way..
Mar 2, 2011
489
Compac 14 Charleston, SC
I used a couple of "cheap" Harbor Freight" panels mounted on the sliding hatch over the companionway on our Hunter 23.
We only used one Group 24 deep cycle for powering a 50lb thrust trolling motor for getting in/out of the marina and minor things like cell chargers, led lights and a radio. The two 15 watt panels kept the battery topped off between weekend trips and we never drew down the battery enough to need more.
Location wasn't optimal but it was the only place that made sense on this boat.
Next time, I'll mount off the stern rail and go with a better controller and panels.
