Leaning more and more that way..
Got my eye on an 80 watt Bosch Monocrystal Panel with a 10 watt Dual Battery PWM controler that should monitor each battery seperate...
Then that leaves me the option of adding another 80 watt down the road if I need...
Only a few bucks more than the 40 watt panel, but the 40s a bit smaller so may be easier to store on boat...But I'm thinking I may want the "recovery" of the 80 watt in case I go out more often than last season...
Maybe I should just get the 100 watt roll up and be done with it...
