Step by Step
Pres,I just went through this. Take my hand, and follow me.My problem was a choked-off fuel supply caused by a clogged screen at the end of the pick-up tube in the fuel tank. CHECK THIS FIRST by taking off the outgoing fuel line, then taking off the brass fitting on the tank & pulling out the pick-up tube. If the screen is clogged with 24 years of grime, toss the screen & reassemble. You might be good-to-go right there and will have solved your problem in 10 minutes, including putting the cushions back.If it doesn't start after that, something else is interrupting the fuel supply to the injectors. Then it's a matter of either:1) bleeding the air out of the injector lines as Ross recommends (as easy as bleeding brakes), or2) finding the supply problem between the tank and the engine.On the 5411 (M25), you will see three metal high-pressure fuel lines coming out of the injector pump on the right side of the engine, curving up, over, and then down to feed each of the three injectors.The tops of the glow plugs stick out from the head at an angle below each of these tubes, and can be identified by the thick wire that supplies current to all three of them.You can test the plugs simply by trying to heat them up for 30 seconds and then feeling the tops that protrude from the head. Be careful: they get very hot. If they don't, suspect the wiring/switch before the plugs themselves.Diesel engines are very simple. Diesel fuel combusts because of heat and pressure (you've got 22:1 compression), so chances are very high it's going to be a fuel supply problem.You're going to start at the injector caps, checking for fuel, and work your way back, component by component, until you identify the problem.Ross' instructions are right: crack a line loose with a wrench where the metal tube attaches to the injector, but don't twist it open. Have someone hit the starter while you slowly open the nut a bit. There should be a squirt from it every time the injector pump sends a pulse of fuel down that line. If it's good, move on to the next one. If there are bubbles, bleed them out, then close the nut. Air could have entered the system when the filter was changed. If so, the cylinder will begin to fire as soon as the air is gone and you tighten the nut down again. Check all three in this manner.AFTER EVERY 30 SECONDS OF STARTER TIME, DRAIN THE MUFFLER, or seawater could back up into your exhaust ports and into the cylinders: nasty expensive.If you loosen each nut but have no fuel flow (which is my prediction), you have a fuel delivery problem, not a glow plug or air bubble problem. Then it is simply a matter of checking each component in your system until you find the origin of the failure. Working backwards, in my C30 with the M25, are the following components:1. Short fuel line from secondary filter to the Bosch injector pump. It's kina big to be clogged, but don't assume: blow through it.2. Secondary fuel filter. Unscrew it: should be pretty full of fuel. If it' not, it' because the injector pump sucked it half dry & it's being starved from farther upstream.3. Medium length fuel line from the Facet electric lift pump to the secondary filter. Remove both ends & blow through it.4. The Facet electric lift pump. Disconnect lines, run a supply line from a small container of fuel & a return line back into the same container, then turn on ignition to see if it has a healthy outflow (it has an internal screen that might need to be cleaned by twisting off the cap of the pump & removing the innards). It should run constantly whenever the ignition circuit is closed. If it doesn't, check the wiring or suspect the unit. If it buzzes, but doesn't put out, it's either the screen (not likely) or the pump is shot.5. The water separator/primary fuel filter. Spin it off, spin off the water trap. Unlikely to be the problem, but if it's old, replace it.6. The long fuel line from the tank to the lift pump. This one might be full of fuel: hold it high when you diconnect it, and blow backwards toward tank to check for clog.7. The pick-up tube in the tank (but you did this first, and saved yourself an whole afternoon, remember?).Note: your lift pump may be plumbed before the primary, which is an older factory arrangement.Only after you're certain all components are delivering fuel to the engine should you suspect anything on the engine itself: the likelihood is fuel supply, & it's a cheaper fix, too.Good luck, and come back to tell us how it's going.Jeff
