Hi All:As the season is winding down, I finally encountered a head problem- or, more accurately, a holding tank problem. Not a design nor manufacturing flaw, rather I suspect some un-kind guest flushed some non-single ply TP down the head. Result is the hose that drains from my holding tank to a thru-hull to dump (where legal and environmentally correct) is clogged. Seems like the solution is to run a auger (kind of rain snake thing) down through it via the inspection cover on the top of the tank. Boat is a 2003 Bav 38 two-cabin config. Any experiences/knowledge with this?Thanks in advance- hope to see some of you at Annapolis in Oct !-Mark
