Ghost living in my boat
May 21, 2015
1
Oday 240 Parlin
Hi All,
A question from a newbie. I've noticed a relatively small (12.5 mA) current drain when all switches on the control board are turned off. Opened the panel and found one terminal connected directly to the "hot rail" labelled #68. I disconnected it - the drain is gone but I don't see what is disabled now - everything seems to be working just as before. Does anyone know what was that?
Regards
Best way is to follow the wire...........
Sometimes the ONLY way.
Good luck.
geehaw
May 15, 2010
231
O-day 25 shoal keel Valdez
Do you have the switches that light when you turn them on? Do they still light?
Pat
Jun 7, 2004
1,250
We had the same thing 10 years ago and it was the radio drawing power to support the clock and memory. Good luck!
Ward H
Nov 7, 2011
3,833
Some recommend to connect your fixed VHF directly to your battery so a bad breaker or switch does not prevent it from working. Could be that or the memory pwer as Pat and woodster said.
